I had an issue with a product call Brightscreen using the spot meter mode on my D3s with a TC14E and TC20EIII attached. The meter works fine without the TC's attached but overexposes 5+ stops if either are attached. Switching to matrix mode seems to work OK with the TC's. I switch the Brightscreen back to the original screen and spot metering now works correctly with the TC's.
I've been using this screen for years but I must have never used spot metering with a TC attached.
The Brightscreen used a 45deg slip image in the center surrounded a circle of microprisms.
framer
