Hi guys
Hopefully you can help me with this problem:
In March 2015 I bought a D4s and a spare battery (EN-EL18a). I never had any issue with the batteries. This year, in July, I bought a third battery (to be sure to have power on my trip to Iceland so I wouldn't end up in places where I couldn't recharge and so... end up with empty batteries).
My three batteries have been working well until some three weeks ago.
The batteries lasted for weeks (I mainly do automotive, autosport and landscape photography).
I noticed that a fully charged battery just lasted one week, while not even using the camera. It (the camera - and yes, it was turned off) just was laying on a shelf...
I've read some issues with the D4 and battery drain due to some network settings switched on. I've checked that specific setting on my D4s but it wasn't enabled.
Is my D4s draining the batteries or is the charger MH-26 causing the problems? Can someone help me or give me some advice or tell me what to do?
I've been looking on the net and several Nikon sites but I can't find anything appropriate.
Not sure if any other members with a D4/D4s can give you more help on this.
Do your batteries call for calibration when you insert them into the charger? (page 459 in the manual)
Check the battery info in the setup menu with each of your batteries. You can see whether they are in need of calibration and the relative age of the cells. (page 365)
The current firmware version installed on my camera is 1.30. Tomorrow I'm going to upgrade to firmware 1.32 (had already seen in this site that there's a new firmware).
The charger hasn't called for calibration, once in the camera all three batteries show positive info: the battery life status is 0 (new).
But I've exectuted a calibration myself with the batteries... I assume that's not a problem? Even if the charger didn't notice me it wasn't neccesary...
I still think you might have network enabled. In the "Network" menu, you need to go into the the "Network Connection" submenu even though it says "OFF" (I think this means "no connection") and make sure that you explicitly select "Disable". Worth checking anyway.
Hopefully everything now is solved.
I'll keep you informed.
Many thanks already for your info and reactions.
