WB for snow
KillerbobKillerbob Posts: 732Member
edited November 2013 in Nikon DSLR cameras
The snow is covering our mountains already, and it is time for me to again take snow pictures. Now equipped with my D800 I wonder if I need to set the WB specifically for snow conditions. I took a bunch on Saturday, and the snow is way too blue. I tried with the WB set for cloudy and sunny, but alas.
So, time to try what Kelvin setting is best. Any suggestions? Lots of snow and ice, and usually rather sunny...
    Here in Vermont, we don't have quite as much snow as Greenland, but we're not far behind. I can't speak to WB, but in snow I do tend to shoot +2/3 EV. You may find that solves some of your issue.
  • shawninoshawnino Posts: 453Member
    Have you already shot a patch of snow in sun to use as a custom WB preset? Did that help at all?
    I knew about the EV setting, and the guideline here is +2/3 -> +1 step, and that helps, but not enough.
    I thought about the PRE setting, but have never dealt with that. I guess that is "simply" pointing the camera at some snow in the given environment, and recording that as white:
    1) Press WB button, move the dial to PRE, and select d-1,
    2) Let go and press down WB button until it blinks,
    3) Shoot the snow.
    However, I thought that was for grey cards... does that work for snow as well?
    I've never used the "Pre-" function as anything other than a way to establish neutral gray (I used an Expo Disk). I'd be curious how this works for you Bob.
    According to the D800 manual page 155, either gray or white can be used with the "Pre" function. I've used it with white before on other camera models, so you shouldn't have an issue.
  • aquarian_lightaquarian_light Posts: 135Member
    Well seeing as how snow is about as white as scenery can get, it will reflect darn near the whole spectrum from the sun, making it VERY easy for the camera to pick a WB in auto mode. Typically there are a lot more colors in an environment which can hide a slight blue cast, but in snow, just let the camera figure it out. I'd bet money on it getting it right.
    D800E, 24-120 F4 VR, 50mm 1.8G, 85 1.8G, 28mm 3.5, 135mm 3.5
    Cameras meter for 18% gray, not white. Snow throws off AWB a lot, you just end up with the blue cast if you rely on that. I just fix the issue in post.
    I did try to leave it in auto mode, and the snow was blue. I then tried in cloudy and in sun modes, and the results were disappointing to say the least. I'll try meter a PRE of the snow next time, and use the custom WB setting.
    White snow can reflect a lot of blue sky this being more prominent when we see it in the shade. ….if you shoot some tests in auto WB, matrix metering, + 0.7 ev, + 1.3ev, +2 ev. and see which ones will hold highlight details, then from there any other corrections can be done in post. You should be able to adjust the blue and yellow in post both from a saturation and luminance basis. When we look at the snow, our brain tells us it is white even when reflecting blue sky. The camera does not do this.
    Now I can't until it is sunny again. The landscape up here in Greenland is fantastic most of the time, and right now with sunny days and powder snow it is even better... Especially around 15-hours, just before sun set ;)
    Same for lightroom.
    Custom WB - that is the only thing that has worked consistently for me. Expo disk, grey card, etc. Sometimes I "bracket" or take two images, shade for elements, custom WB for snow and combine the image.
    Using Aperture I find that the WB tools are OK. I never use Lightroom, and only Photoshop when I need the heavy machinery out:)
    I'll try the Kelvin +500 step-up, and the custom WB settings and see what I get...
    White balance can be bracketed ;-)
    Page 138 in the D800 manual, you can set the increment at 5,10 or 15 mired.
    Like Tao, custom WB works best for me with snow using the ExpoDisk. I have also had too tweak the expose. That was based upon my D300. We just got our first snow of the season and I did not get out the D7100.
    Bracketing is a good idea, at least in the beginning, and when shooting something as challenging as sonwy conditions. Also for landscape pics it is doable.
    I still use a grey card. Anyways shoot raw... a little toying in Lroom will show which kelvin it is to be at
  • NSXTypeRNSXTypeR Posts: 2,286Member
    Interesting, I put my white balance on auto and everything worked out fine.
    DSC_5874
    I never really gave a thought about WB. It just came out okay.
    @NSXTypeR
    If you look at shadow areas (e.g., bottom left corner of your picture), the color of the snow there is quite blue. If you take a loupe in Photoshop you'll see RGB values like (R=67, G=79, B=105). To me however the picture looks natural, and it's ok to have bluish snow in shadow areas if it doesn't dominate the picture.
    So the rule of thumb with snow is to ensure neutral color balance in the highlight areas (properly exposed), and let the rest naturally fall in place. One can go nuts trying to eliminate the blue tint everywhere.
    Post edited by Ade on
    One of the difficulties in viewing any scene on our computers in which color is critical, is the lack of uniform color balance between all our monitors. It may appear correct in terms of what we see on our monitors, which we may have even color balanced for our preference, but once on the web, the color may be something different.
  • BesoBeso Posts: 464Member
    Here is a link discussing white balance in snow ... as well as exposure metering and compensation generally.
    http://bit.ly/Vowp0F
    Post edited by Beso on
    Occasionally a decent image ...
    @NSXTypeR
    @NSXTypeR: I have to agree, it looks far too blue to me. The shadows are far too blue and the trees are no longer green. I added a couple of curves adjustment layers, one that targeted the shadows and the other the midtones. I worked mostly with the blue channel, but did some changes to the green as well. It's not raw, so it's tough, but you'll see that it no longer has as much of a purple/blue cast.
    Interesting points- I never would have noticed that the trees looked more black than green. I guess I should pay more attention to that stuff, and take a look at making a custom white balance perhaps.
    @NSXTypeR: the more you play with your RAW files in post the better your skills will get. The only thing you should pay attention to is to avoid getting to many blown out spots. My recommendation to avoid it is, meter the sky to get the proper exposure, then do not change any of the setting. Re-compose to the spot you what to shoot and fire away. This way, your RAW files will have all the info it needs in post. The LCD on the back of your camera will also help, when you preview the images to see if their are any blow-outs. If the image is dark, by all means DO NOT worry about it...you will be able to get all the colors and proper WB in post.
    Have fun and looking forward in seeing your images on PAD.....cheers.
    We should ALL be using some form of colour management! If we only click snaps and put them on flickr i.e. viewing them on our own PC screen only then we cannot know how far out of whack they are. Spyder or Colour Monkey are two I have used.
    This is an example of what I got:
    D80_3057
    I don't think it is good enough... The sky was actually not that grey/yellow, and the ice is still turning bluish...
