My Nikon 3200 wifi will not stay connected
thennessythennessy Posts: 1Member
edited January 2013 in Nikon DSLR cameras
Camera connects to IPad but halfway through download of photo it disconnects. Any suggestions
    First, we need to know the Image Quality settings of your camera. For the WiFi connection, the recommended file size is JPEG/Fine/Medium. If you are using a larger file than this, it may not work.
    Welcome to NRF
    Check your timeout settings. Is the camera going to sleep before the download completes?
  • Nikon_BratNikon_Brat Posts: 5Member
    I've had timeout sessions with my iPad 2. maybe the new iPad's don't have the disconnection as much. However I will say I was rocking the app on Android way better it came to iOS. Never had problems with Android in either HTC EVO 4G or Galaxy.
  • ricewingricewing Posts: 1Member
    I realize this post is several years old, but I have been experiencing this problem as well. Quite by accident, I found out that on my iPhone, and iPad, if I have both Wi-Fi and Bluetooth turned on at the same time I get the described problem. I found that if I turn off Bluetooth the problem seems to be resolved. It worked for me. I hope it works for you.
  • CrimzaelusCrimzaelus Posts: 1Member
    Yes, I had the same issue where it would disconnect or not transfer the photos. Once I turned off Bluetooth on my iPhone, it worked perfectly!
